Page 1 of 1
Refresh My Old Memory
Posted: Tue Aug 23, 2016 8:12 pm
by davery
When I took the center console out many moons ago it seems I didn't write down how the shift boot is held in place. Does the shift boot retaining ring fit inside the boot? If so, that would mean the "wood" edge around the shift opening shows? Thanks.
Re: Refresh My Old Memory
Posted: Tue Aug 23, 2016 8:20 pm
by lglade
Yes the ring goes inside the boot. But the ring is an outward facing C-channel, so the wood section sits inside the mouth of the C when the boot is installed. So you can't actually see vertical edge of the wood.
Posted: Tue Aug 23, 2016 8:50 pm
by davery
lglade wrote:Yes the ring goes inside the boot. But the ring is an outward facing C-channel, so the wood section sits inside the mouth of the C when the boot is installed. So you can't actually see vertical edge of the wood.
That's what I thought. Thanks.
Posted: Tue Aug 23, 2016 10:36 pm
by DieselSpider
Here is the old IAP video covering the replacement of the center console and about half way through includes the replacement of the shift boot:
https://www.youtube.com/watch?v=C38zb84UQLI
Posted: Sun Apr 07, 2019 10:03 pm
by mootept
Anyone happen to have a to-scale template for the console wood insert ('70) ?
