Refresh My Old Memory
- Your car is a: 1985 Spider
When I took the center console out many moons ago it seems I didn't write down how the shift boot is held in place. Does the shift boot retaining ring fit inside the boot? If so, that would mean the "wood" edge around the shift opening shows? Thanks.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- lglade
Re: Refresh My Old Memory
Yes the ring goes inside the boot. But the ring is an outward facing C-channel, so the wood section sits inside the mouth of the C when the boot is installed. So you can't actually see vertical edge of the wood.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
That's what I thought. Thanks.lglade wrote:Yes the ring goes inside the boot. But the ring is an outward facing C-channel, so the wood section sits inside the mouth of the C when the boot is installed. So you can't actually see vertical edge of the wood.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
Here is the old IAP video covering the replacement of the center console and about half way through includes the replacement of the shift boot:
https://www.youtube.com/watch?v=C38zb84UQLI
- Your car is a: 1970 124 Spider Sport
Anyone happen to have a to-scale template for the console wood insert ('70) ?
