Has anyone come up with a fix for the filler neck hose. IAP suggests carefully cutting another applications hose. I have a 76 Spider. The head of the OEM clamp wore a hole in my hose. Mine can't be the first so I figured someone here on the Forum has a slick fix. Thanks in advance for the help.
Jim
Fuel filler neck to tank hose
- Your car is a: 1980 FI Spider
Re: Fuel filler neck to tank hose
Gates makes one with a 90 elbow, part number 24717. You do need to trim it to length. Important to use fuel-rated hose here.
1980 FI Spider
- johndemar
Here's a OEM on eBay. Don't have a direct link, but this is the item number.
350345457917
350345457917
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
