My '80 fuel injected spider suddenly developed a hesitation under load that typically occurs while going through the gears, between 1500-2500 rpm. It is never really bad, unless I try to lug it in 4th while going slow.
I would think if the fuel pump were going out or the fuel filter clogged, the hesitation would get worse with load/rpm.
Idle is also fine (a bit rich, but stable).
I plan to tear into it this weekend, so I am looking for some suggestions.
mild hesitation under load
you should get a copy of the FI diagnosis manual and have a volt/ohmmeter for measuring resistances. Without those, you're pretty much reduced just checking connections.
I'd make sure the intake boot isn't cracked and the AFM flap moves thru its' range without binding. Inspect any other vacuum hoses also. Air leaks will drive your FI system crazy, so look the intake system over closely
