Page 1 of 2
Refinishing this area under the cowl?
Posted: Sat May 08, 2010 11:06 pm
by Fiat88
What kind of coating would you guys use on this area, the original rubber type coating is kind of cracked. I'm thinking of using eastwood's extreme chassis black paint and a can of seam sealer so i can redo the seams. What have you guys used? THx.
Re: Refinishing this area under the cowl?
Posted: Sat May 08, 2010 11:22 pm
by SLOSpider
I just used a good undercoating
Posted: Sat May 08, 2010 11:36 pm
by johndemar
I covered mine with POR-15. In fact almost all the surface that isn't painted the body color is covered with it.
Posted: Sun May 09, 2010 4:24 am
by Curly
Removed the old seam-sealer with knife, sandblasted all the paint off, reapplied seam-sealer, treated with etch primer same as rest of body and then the usual primers and top-coats to finish it off in body colour.
Posted: Sun May 09, 2010 2:05 pm
by Fiat88
Might try the Por-15 stuff, is that stuff ok to use on good metal as I don't see any really rusty metal?
BTW, is the center air intake flap that's controlled by the heater lever removable? As it has a good amount of surface rust. Want to take it off and sand it down to good metal and repaint.
Posted: Sun May 09, 2010 2:17 pm
by manoa matt
I used an actual roofing product after prepping it and painting. I figured it was much thicker than paint and would hold up better. It rains all the time here and mine is a daily driver so that area sees a lot of water.
Posted: Sun May 09, 2010 2:49 pm
by ventura ace
Try to build up the bottom so that the water will always drain out, and not collect. The problem happens when residual water sits there for a long time without draining out. A little bit of a design error from Fiat made it so that the drain is not quite at the lowest point. A little shaping with bondo should do it.
Alvon
Posted: Sun May 09, 2010 4:07 pm
by SLOSpider
Yes it can be removed. Open cover as much as you can then undo the hold screw for the cable inside. Then you can open cover more and access the 2 nuts on the bottom. While you have it out make sure it moves free on its hinge and lube it down so its moves easily . you can see one of the nuts in this photo
Posted: Sun May 09, 2010 11:15 pm
by Fiat88
SLOSpider wrote:Yes it can be removed. Open cover as much as you can then undo the hold screw for the cable inside. Then you can open cover more and access the 2 nuts on the bottom. While you have it out make sure it moves free on its hinge and lube it down so its moves easily . you can see one of the nuts in this photo
Thanks for the pics SLO! Sanding will be much more easier but I wish I had a blasting cabinet...oh well sand paper will do! :mrgreen:
Posted: Wed Mar 21, 2012 2:10 pm
by jimmycakes401
Ventura, what do you recommend for building up near the drains? I have some fiber fill. Easy to use, rock hard after curing then top coat it? Sound like a plan?
Posted: Thu Mar 22, 2012 10:13 am
by 124JOE
jimmy it sounds good here
:wink:
Posted: Thu Apr 05, 2012 1:10 pm
by jimmycakes401
Trying to screw my cowl back on right now. I'm not sure which of my fastners are supposed to be in there. Since I didn't take it apart, I have no idea. Anyone remember if it is a phillips head screw top or a rachet top? Maybe have a picture?
Posted: Thu Apr 05, 2012 3:34 pm
by seabeelt
They are phillips screws (located in holes along the edge that is toward the engine compartment)
r/
Posted: Thu Apr 05, 2012 4:30 pm
by jimmycakes401
Excellent. Are there washers?
Posted: Thu Apr 05, 2012 6:19 pm
by Ky2000
Yes, mine had rubber washers that where shot, so i replaced them.
