Stub Axle Nuts - Thread and Torque
ITA124
Post by ITA124 »
Hi All,
I have done this a few times before, but thought I get your input. Can you guys confirm this
Thread:
Left Hand hub has a RH thread
Right Hand hub has a LH thread.
This is what the book says, but looks odd. When I turn the wheel. The nut looks to undo.
Torque:
Preload to 15ftlbs
release and torque to 5ftlbs
Back off 30 deg (1/2 a flat)
This leaves the nut only finger tight. When the tabs are knocked in, I can lightly jiggle the nut.
Is this what you guys do?
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
mdrburchette
Re: Stub Axle Nuts - Thread and Torque
Post by mdrburchette »
It's opposite of what you would think so that is correct. They're not going anywhere once you bend the tab in. I can't find torque specifications in my book so maybe someone else will chime in.
kmead
Post by kmead »
ITA124 wrote:Torque:
Preload to 15ftlbs
This is what one does, there are a few things left out:
Rotate the hub in both directions 4-5 rotations in each direction to seat the bearings while it is at the heavier torque.
Another thing left out is checking the runout which shouldn't exceed .005" which can only be seen with a dial indicator. If it does exceed that amount they suggest redoing the entire process.
It is a bit fussy, I confess I have tended to run my car a bit tight with no ill effects (so far). Be sure and use new nuts each time.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
kmead
Post by kmead »
Dbl Pst
Karl
1985 Bertone X1/9
