help me on my fusebox.....my heater wont shut off
what fuse can i pull out to shut the heater off......i live in so cal and its hot as it is....if i pull the fuse will other things shut off?...or is there a wire i can cut......somthing...please help or if anyone knows a website thatl tell me ...thanks_______Brandon
if the fans on just unplug the switch on the console. if the fans not on and the cable levers [ on the center console] are both down and in the forward position, and your stilll getting heat. go under the hood and bypass the heater by rerouting the hose. look at the hose at the back of my engine in this pic.
