FUEL PROBLEMS
FUEL PROBLEMS
HAVE AN 80 PININFARINA,BELIVE IT HAS FUEL PROBLEMS. HAVE HAD INJECTOERS CHECKED OUT . ARE FINE. INSTALLED NEW FUEL PUMP, NEW FUEL TANK, NEW FUEL FILTER, STILL FALLS ON ITS FACE WHEN STEP INTO IT. ANY SUGGESTIONS?
- manoa matt
Re: FUEL PROBLEMS
If it has problems, then what are the symptoms? Always check out the ignition system before moving on the the fuel system. Its components are cheaper, and is usually the fault.
