Trunk Height Adjustment
I am currently re-assembling my 81 Fi and have found the trunk lid to be quite high at the hinge points. This causes the entire trunk to sit higher than preferred. I cannot see any way of adjusting the hinge height and the other adjustments do not improve the look. I need to lower the lid by about 3/32" or more. Before restoration I never noticed this as the car was battered up and dull paint. Any ideas? If I had caught this prior to paint I could have done something physical to it.
Re: Trunk Height Adjustment
I know the lid is bolted to the hinges,but how is the hinge attatched to the body? if bolted a couple of washers there to lower?
Mask the area off and grind a bit on both hinge and lid?
The hinges are welded... not enough to grind off already thought of that.... dumb design reallynarfire wrote:I know the lid is bolted to the hinges,but how is the hinge attatched to the body? if bolted a couple of washers there to lower?
Yet another reason to own an early model
You bugger... Yah just had to get that one in.... Laugh.baltobernie wrote:Yet another reason to own an early model![]()
- wachuko
- Your car is a: 1981 Fiat 2000 Spider
- Contact:
So that is how you activate the trunk light!!!!
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
