gap specs
chief
gap specs
Post by chief »
Does anyone know what the gap specs are for the points for the 76 spider?
Thanks Chief
ga.spyder
Re: gap specs
Post by ga.spyder »
Hey Chief,
The gap is 0.017 to 0.019.Any luck gettin' er going?
Craig
Craig Nelson
Fling It Around Turns !
Re: gap specs
Getting the dwell right is more important than the gap. Dwell should be 55 deg.
chief
Re: gap specs
Post by chief »
Thanks guy's for the info I will check on the dwell and see what goes.
Yeah Craig it is up and going runs like a sewing machine smooth and sweet.
Had to bypass the ignition relay, but had to utilize both sets of points to get it to run
Without sputtering. So new points. How did it work out for you and your coil issue?
Chief
ga.spyder
Re: gap specs
Post by ga.spyder »
Glad to hear you have her running,have you driven it much? I got mine out last weekend,before the monsoons hit!I am not sure what is up with mine...checked all connections,module, mag p/u,injector plugs and it all looks good.The worse thing is it is intermittent,so sometimes I cant even make it skip.Does feel more like an electrical miss,though
Craig
Craig Nelson
chief
Re: gap specs
Post by chief »
Just got back from taking it around the block and it ran pretty good!
I was impressed, can't wait till I put the new points in tommorrow.
Ordered points and brake pads all around for it today and will arrive in the AM.
Is your problem under any certain conditions that it happens or is it just sporadtic?
Chief
ga.spyder
Re: gap specs
Post by ga.spyder »
It is sporadic,always at low rpm(below 2500 rpm),usually in 1st or 2nd gear,and with the engine cold.Its gonna be tough to find!It is a intermittent miss or skip.Very slight to where it might not bother some people...but I'm kinda anal :lol:
ps...I sent you an email re. a car
Craig
Craig Nelson
azygoustoyou
Re: gap specs
Post by azygoustoyou »
Hey guys, what is the dwell? :roll:
ga.spyder
Re: gap specs
Post by ga.spyder »
Brady...its something us guys with modern ignitions dont have to worry with :lol:
Craig Nelson
