Got it running!
Well it was worth it, when I got home it still wouldn't crank.
Previously I had rerouted the PO's wiring job and put everything back to it's original configuration, and it took off like a sewing machine then quit.
After work today I rerouted the wiring back avoiding the relay and it ran but rough it spit and sputtered and would die every five minutes or so.
Then I incorporated both sets of points and it ran again like a sewing machine.
New Points definitly
As for the over heating I took and sprayed the connections to the sensors in the manifold with some electronic terminal cleaner and no more overheating.
I let it idle for about 45 min to an hour with no major problems.
It would sit and idle at about 1250 on the TACH
By the way what are the points to be set at?
Thanks for all the great help you have given so far.
Chief
ps will post some pics as soon as possible
rain for the next four days or so.
