Forget the flag pole and cross your fingers
Anything goes (within forum guidelines of course)
amsiegel
Post by amsiegel »
All
I just heard from Red. He was heading down from Jacksonville to the Car show in Zephryhill. His transmission started making a noise around the Gainsville area. He is turning around and heading home. He probably has at least 100 miles to go.
So cross your fingers, go out to your car and give your transmission a nice rub (it might work)and lets hope Red makes it back with out to much damage.
mdrburchette
Re: Forget the flag pole and cross yopur fingers
Post by mdrburchette »
May the Fiat gods have mercy on his transmission.
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: Forget the flag pole and cross your fingers
Post by wachuko »
I just left you vm asking how things were at the event... man!!
He had been working on his transmission in the past few days and was trying to stop a leak.
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
red107
Contact:
Post by red107 »
Well my wife and I were blessed by the fiat gods. We made it back to jax. My transmission will have to be pulled. I will know the damage then. It shift fine. But makes a loud knocking noise in 1,2,3,and 5th. 4th was the only quiet gear. Also there was a serious whine so it sounds like the bearings are toast. Not to mention it still leaks so bad. We drove on a curb and the wife and I pumped more fluid in it and limp home. Thank you all for your prayers
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
wachuko
Contact:
Post by wachuko »
Glad you made back home safe. Let us know what you find. :(
Drive Safe!
Wachuko
2015 FIAT Abarth
amsiegel
Post by amsiegel »
Maybe this show was cursed. The little 500 abarth thing had some problems the show, a Jaguar got a flat, leaves got into everyones cars because it was all under trees. Not to mention there was a bird in tress that crapped on at least 6 cars. There was a 1940 Triumph (I think) convertable that got its rumble seat covered by the bird.
When I was pulling my car into the warehouse I noticed a rattling noise coming from the engine. I think it has to do with the valves. Will have to check it out when I have more time. I will post photos later.
