what is this?
what is this?
Is this the sway bar? Stabilizer? What is it. i need new bushings for it but I don't know what it's called.
- Your car is a: 1972 124 Sport Coupe
Re: what is this?
There are four bushings. Another center one, and two others, one on either end.
Re: what is this?
Boy, it looks just like an oil filter.
Jim
Jim
Re: what is this?
har har har... I was thinking the same thing Jim.
time for some INSTALLATION fluid !!
Re: what is this?
Oh my gosh you guys are hilarious
But seriously folks, when I take a left turn semi fast like 25 mph my tire screeches like i'm going like a bat out of hell. It only does it on the left corners. That is the side that is missing the sway bar bushing. Would that cause that?
- wachuko
- Your car is a: 1981 Fiat 2000 Spider
- Contact:
Re: what is this?
Get all new bushings.macawlover70 wrote:Oh my gosh you guys are hilariousBut seriously folks, when I take a left turn semi fast like 25 mph my tire screeches like i'm going like a bat out of hell. It only does it on the left corners. That is the side that is missing the sway bar bushing. Would that cause that?
As to the tire screeching... could also be old tires, tire pressure, alignment.... but change all bushings... not just the ones in the front sway bar.
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- engineerted
Re: what is this?
Am I seeing things or is that a nut an bolt sicking out of the front of the oil pan? WTF?
Sorry, its the other control arm, bad angle on the photo.
Ted
Ted
Ted
Re: what is this?
Now that's a fun job. About as fun as replacing a starter. You may want to double check your whole front suspension, including ball joints and like Wachuko says, might as well check and change all the bushings.
Re: what is this?
might as well do all the bushings, ball joints and tie rod ends... betcha everything is the same age and you're gonna wanna front end alignment when you're done anyway. why do all this work in two or three steps?
- wachuko
- Contact:
Re: what is this?
And while all that is apart... why not clean, paint, or powder coat them as well
... then there is the oil pan, you can remove it, push the dents out, and paint it...
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Re: what is this?
Does anybody know where to get poly end bushings for the stock front anti-sway bar? I see the center bushings available from IAP. Thanks
Re: what is this?
The same IAP ones work, but you have to trim them to fit. The center ones are a pain to change, the brackets are peened or rivited togeather thru the bolt holes. I drilled the holes bigger to seperate them. They can be a bear to get squished back togeather, I've heard of a few methods: tack welded back togeather, putting sleeves in the now oversized holes, or the easy way that I did: buy new brackets , squeeze them togeather and peen them back togeather.
http://store01.prostores.com/servlet/mi ... ner/Detail
Trey
