I have a 1978 spider that is a great car. It runs nicely but has begun to hesitate and backfire (it sounds like through the carb) whether cold or warm. This happens under load in first or second and it may pop three times and die (it will restart) or it may pop once or twice and then continue running. The ignition system has been mostly rebuilt. Any ideas for a newbie?
I also have had problems with starting the car. There are times, mostly away from home!, when you turn the ignition and everything lights up but the engine won't turn over. I've regrounded the battery, tightened connections on the fuse block, checked for loose connections on the starter. Last night it did it again, with the trans in reverse. I took it out of reverse and it cranked. It'll crank in neutral with the clutch engaged. What about this one, any ideas?
Hesitation and Backfiring
Starting
I have FI and can't help with first part.
On to starting. Had similar problems. Replaced starter, ran new extra ground wire from battery negitive up to starter front bolt. Cleaned everything. Now starter works great. (this also cleans charging wires)
New starter was $50 at Shucks and comes wtih limited lifetime warranty.
New ground wire (multi-strand #12) from home deport electirical department and cost about $15.
Bandaids to get out top rear starter bolt $.25.
Celebration beverage when all back together and running $6.95.
With a hesitation, it could be a vaccum leak, ck all hoses for cracks, looseness. If your batt is in trunk, you should install a ground cable from eng to a good chassis location. Mine did the same thing, I think it was the connections at the starter, and one burnt connection in connector near ign switch I butt connected the wire. The spade terminal at starter was fixed by squeezin the female spade tighter w pliers.
hes..iii ... tation
I too have a 78 that was giving me difficulties with hesitation. Mine seemed to happen more as the rpm's increased. I changed fuel filter, rebuilt carb, new plugs, new wires, new rotor, new dist. cap.....hmmm..still problems. Then I bit the bullet and removed the points and installed a Crane XR3000 electronic ignition. WOW....it's running like a dream (fingers crossed and knock on wood).
........Haps
78 Spider
........Haps
78 Spider
Good news and thanks to you all! I regrounded the battery in the trunk and went over other connections in the starter wiring and so far, so good.
I'll also reset the points and it's a different car! I'm going to go for the electronic ignition but what a difference a little gap makes. It had almost closed so I'm sure it was close to not running at all.
Thanks folks, you gave me great advice and encouragement and now I'm happy with the car again!
