Jack Tie Down
- courtenay
Jack Tie Down
Can someone take a picture of what the jack is supposed to look like when tied down in the trunk? Mine is loose - and while surrounded by padding still rattles and bangs whenever I go over any bumps in the road.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- kilrwail
Re: Jack Tie Down
Here you go. The exposed bolt end of the jack is towards the front of the car, inserted in the round hole up on the fender. This tool kit is not the original, but it's the same size. (The original is stored except for shows.) You need a rubber strap with rectangular rings on each end, to go around the tool box and the jack, holding them both secure.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: Jack Tie Down
Make sure you have that jack strapped in there. I did'nt have a proper fitting one and the jack must have come loose,cause a couple of hard left turns the end of the jack slamed into the inside of the fender and I now have a couple of "outie" dimples on the fender. Getting quotes on the fix the next couple of days.
- courtenay
Re: Jack Tie Down
Aha - I'm missing the little rubber strap!! Is the tool kit a Fiat item? Don't have one of those either. What's in it?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- kilrwail
Re: Jack Tie Down
You can read all about the tool kit here:
http://www.fiatspider.com/f08/viewtopic ... kit#p61912
If you don't have one, you'll need a much shorter rubber strap.
Peter Brownhill
Peter Brownhill
- courtenay
Re: Jack Tie Down
Thanks, all. In looking at the pictures, I realize that not only do I not have a tool kit, I don't have a tire iron as well. Going to be tough to get those wheel nuts off without one. I think I will have to make my own little kit up and strap it in nice and tight!!
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: Jack Tie Down
There is always Fiat tool kits for sale on Ebay .... keep an eye out !
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
- kilrwail
Re: Jack Tie Down
Unless you're an 800 lb gorilla, you'll want a longer wheel bolt wrench than the one in the standard tool kit - it's only about 8" long! I keep mine with the spare tire.
Peter Brownhill
Peter Brownhill
- courtenay
Re: Jack Tie Down
Thanks, Peter. As I'm only a 260 lb gorilla, I will make sure I get a long wrench.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Re: Jack Tie Down
You should ask the SOB who sold you the car why he did not include the tie strap and toolkit..... Laugh
- boogiedude
- Your car is a: 1978 spider 1800
Re: Jack Tie Down
Who needs a longer tire iron? I'm a 160lb chimp and I have no problem breaking loose wheel bolts with my handy dandy stock fiat tire iron. If you can't pull it, jump on it!
