I have created a new problem while trying to fix an existing one. I rebuilt the front calipers and am trying to replace the rubber hoses. They have welded themselves to the nut on the brake line and I broke the brake line.
So has anyone replaced these lines? Do I need to replace the line all the way back to the master cylinder? Will the lines at the local NAPA store work or is there something special about Fiat?
Brake lines
the brake lines that Napa carries may or may not fit, there are several types of lines used. Fiat used a bubble flare on the ends and the fittings are metric. You'll probably have to replace the line to the master cyl, it's tough to splice a line unless you can flare it on the end where you cut it off. Unions and compression fittings are not normally used on brake lines
Anyone have a source for replacement lines? I checked IAP and they do not carry them. Didn't match anything at the local autoparts store, the threads are too coarse.
The drivers side met the same fate when I tried to replace the hose. And I will not be surprised if the back do so as well. So I will probably need an entire set of lines.
