Transmission mount
ralphcap
Transmission mount
Post by ralphcap »
Can't lift transmission enought to allow installation of a new transmission mount. The spider is on four jack stands and the transmission is being lifted with a hydraulic jack. When I reach a certain point in lifting the tranny the whole car starts to lift instead of just the transmission.It doesn't lift the tranny enough to allow for installation of the mount on the two bolts on the tranny and the two on the bracket. What am I doing wrong?
ITA124
Re: Transmission mount
Post by ITA124 »
I recall having this problem and found that the shift housing was catching on the production joint in the tunnel. Once it gets past this point, there seems to be more room.
Hope this helps
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
take the tranny crossmember out
"take the tranny crossmember out" I think they call that a post-op
