IDF Toys
lanciahf
IDF Toys
Post by lanciahf »
This is how I spent my cold afternoon. :D
I still have to hook up the throttle linkage, choke, oil breather etc.
azygoustoyou
Re: IDF Toys
Post by azygoustoyou »
Looks good! I thought your car was a 2L. I spent my afternoon cutting down a 60' tree and chopping it up. It is about the seventieth tree I cut. I have 15 to 20 more to go. :?
Re: IDF Toys
after looking at the brake booster vacuum fittings, I deduce you are a plumber
lanciahf
Re: IDF Toys
Post by lanciahf »
Noooo that is from the clever hands of the previous owner. I guess Fiat's solution was too simple. I just know this part is going to come back and haunt me.
Brady it is a 2L.
Re: IDF Toys
azygoustoyou
Re: IDF Toys
Are those 1800 valve covers?
racydave
Re: IDF Toys
Post by racydave »
Maybe you can take me for a ride at the FFO! Tail of the Dragon !!!
mdrburchette
Re: IDF Toys
Post by mdrburchette »
Did you finally find all the parts you need? Can't wait to see what you think of those carbs. What kind of air cleaner are you going to run?
lanciahf
Re: IDF Toys
Post by lanciahf »
Brady, the valve covers are from a 79 spider.
Denise, still looking for a throttle bell crank, I bought some air cleaners from CB Performance, The oval chrome ones, around 2.5" high.
Hopefully if the weather cooperates I can start it next week. I'm still playing around with a Volvo 240 radiator conversion.
mbouse
Re: IDF Toys
Post by mbouse »
wow! 2.5" that far forward in the engine bay? best of luck with that.
i'll take a ride after Dave at the Dragons' tail in July
mdrburchette
Re: IDF Toys
I installed a Volvo 240 radiator in my Lemons car that fit with a couple of modifications. It's a tad wider than our stock radiator. The one thing I would do is have a custom metal purge tank made that would fit where our overflow bottle sits. I used an electric fan I bought from Advanced Auto that cost about $70 that mounts to the radiator itself with plastic ties that go through the fins.
lanciahf
Re: IDF Toys
Post by lanciahf »
Hi Denis,
Funny you should bring up the width. The first time I did the conversion it was no problem fit wise. I bought the radiator from Rock Auto and it had plastic end tanks. This radiator I found off craigslist is all metal construction and is about 1/4 to wide. I slightly tapped the offending parts with a hammer and all is okay.
What did you do for a bottom and top mount?
mdrburchette
Re: IDF Toys
We used the original lower support and made a mount for the top of the radiator. It may not be something you want to do with your Fiat since it requires drilling holes in the radiator support, but it's a nice stable install.
lanciahf
Re: IDF Toys
Post by lanciahf »
Do you remember what you used for the lower hose or did you splice two together?
mdrburchette
Re: IDF Toys
I cut to fit some X19 hoses I had laying around.
