Oxygen sensor
Jimb
Your car is a: 1985.5 Volumex
Oxygen sensor
Post by Jimb »
I just got my first spider and was having a good poke around the engine bay and noticed that the oxygen sensor is unplugged. Is this accidental, or common for some reason?
Thanks,
Jim
Re: Oxygen sensor
common "solution" for owners that don't know how to diagnose FI trouble. Plug it back in
Jimb
Re: Oxygen sensor
Post by Jimb »
So Cal Mark wrote:common "solution" for owners that don't know how to diagnose FI trouble. Plug it back in
Thanks for the reply.
She's carburated, but I will plug it back in, once I've figured out where. :?
Cheers,
Jim
maytag
Re: Oxygen sensor
Post by maytag »
what year is your caR? was it originally carbureted? Or is that someone's conversion?
I'm no Fiat expert, but I'm having a hard time figuring-out what your carb'd car would be doing with the signal from an O2 sensor?
I'm about to install an o2 sensor in my carb'd car, but for a very specific purpose, and one that means I wouldn't need to plug-in the wire for any purpose other than when I'm tuning the motor.
htchevyii
Patron 2022
Patron 2022
Re: Oxygen sensor
Post by htchevyii »
Be careful leaving it unplugged, but installed if it's a heated o2 or wideband a/f sensor, it'll be ruined.
Trey
Re: Oxygen sensor
if you have a carb rather than FI, there shouldn't be any wire to plug it into. Just leave it.
Jimb
Re: Oxygen sensor
Post by Jimb »
So Cal Mark wrote:if you have a carb rather than FI, there shouldn't be any wire to plug it into. Just leave it.
The car is an 85, supercharged.
Jim
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Re: Oxygen sensor
Post by kristoj »
Is it a Volumex model?
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
Re: Oxygen sensor
rather than have us play 40 questions, it would be helpful if you post all of the pertinent info about the car and particular problem you're having
Jimb
Re: Oxygen sensor
Post by Jimb »
So Cal Mark wrote:rather than have us play 40 questions, it would be helpful if you post all of the pertinent info about the car and particular problem you're having
Sorry, I didn't intend for this to produce a 40 question quiz.
I started out by saying I had just received my first Fiat and while digging around in the engine bay I discover what I believed to be the oxygen sensor unplugged.
My question then was....does anyone know of a reason for this or would it likely have been accidental?
I do not have the car registered yet, so it is not driveable...however when I picked her up from the shipper I had to drive her 1/2 hour or so home...and there were no signs of anything wrong.
The car is a 1985.5 Volumex.
Thanks again for all the feedback.
Cheers,
Jim
maytag
Re: Oxygen sensor
Post by maytag »
Jim:
all we were trying to convey was simply that you will be much, much happier with the accuracy and completeness of the responses you receive if we have ALL of the pertinent information; particularly that you have a (comparatively) rare car (Volumex) that will certainly have many systems and components which differ from the standard models.
You posted what seemed to be a complex conundrum; O2 sensor on a carb'd car. To tell us that it is carb'd, but not mention at that point that it is a Volumex is beyond incomplete, and borders on misleading.
Jimb
Re: Oxygen sensor
Post by Jimb »
maytag wrote:Jim:
You're absolutley right.
However, at the time of my original post, I didn't know that fuel injected vs carburated was relevant.
My apologies, I will try to exercise better "keyboard annunciation" next time. :oops:
Cheers,
Jim
Re: Oxygen sensor
I wasn't trying to come too hard on you, but as stated previously, without all of the info misdiagnosis or poor advice will be the most likely outcome.
kristoj
Re: Oxygen sensor
Post by kristoj »
Man, you guys are cranky tonight! Jim, welcome to the forum. You have a very rare and desirable car. Certainly the most valuable of all the 124 Spider variants.
Please post some pix and tell us the story behind how you came to acquire your car. Did you ship it home from overseas? The Volumex was never officially sold here.
John
John
'12 Abarth 500
pope
Re: Oxygen sensor
Post by pope »
Look Jim,
We do demand pictures of every possible position of that engine bay. It is a rare sight to see a Volumex and I would appreciate some pics to see clearly what they did with that engine.
Cheers to you and welcome.
I am salivating in anticipation.
I certainly dont have the wiring plan for the 85.5's when they went back to carbed for the Volumex. I would replace the oxygen sensor with a new one once you find out where it plugs into.
