I have committed the cardinal sin (several) and I need help ASAP please.
I committed the sin of too many things at once, timing belt, AND distributor rebuild at the same time. I am trying to button everyhting up and get herrunning today and it won't start.
FIRST, I know the timing belt is correct. All four marks line up perfectly, the crank at 0*, both cams with holes at pointers and the aux. shaft index at 1 oclock.
Second, the plug wires are correctly wired, cap is marked with firing order and cylindersa re 1-4 from front to firewall (correct?).
Where I went wrong was two fold:
I did NOT mark . index the distributor / block before I pulled it out. I read the instructions for removal and install and figured by lining up all the timing marks and install the distribuotr with #4 firing I would be close enough to get it to run by slight dist. movement.
Here is where I MIGHT have misunderstood / gotten it bass ackwards - the manual says to line up the marks and set the distributor in with #4 firing. Is that the crank mark only (cams 180 out) or all marks aligned (cams and crank marks lined up? I suspect now that it is the latter and I am 180 out since I set it in on #4 with the crank mark aligned but the cams 180 out. It is sparking but I got the kind of backfire that says 180 out. Befroe I go out and swap it can anyone confirm the correct alignment?
BTW, I know to NOT keep cranking / trying while possibly 180 out as i blew the exhaust off a 1061 Cadillac convertible that way once!
Dist in 180 out? Please help ASAP
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
