brighter Light Mod Schematic
Gotta love that wiring . . .
SpiderJim
Post by SpiderJim »
Anyone know where the schematic for the brighter light relay mod is? Saw it once and cannot find it now!. Should have saved the link derrrrr. Any other good mods around.
danaspider
Your car is a: 1979 Spider 2000 79 vw bus
Re: brighter Light Mod Schematic
Post by danaspider »
Search the site for Brown wire surgery. That will get you the info you need.
Luck Dana
79 Spider 2000
carb
mbouse
Post by mbouse »
are you at the right forum? this is FIAT SPIDER dot COM. there is no such thing as a brighter light relay. there is dim and dimmer.
are you referring to the dash light rheostat? it is a simple rheostat with two wire connections. my recommendation is to bypass that rheostat and jump the two wires together. who wants dimmer lights anyway.
if it is BROWN WIRE SURGERY you are after, here is the link to my method:
http://flumichigan.italiancarclub.com/T ... urgery.pdf
if none of this answered your question, please let us know.
SpiderJim
Post by SpiderJim »
I guess I should have said brighter head light mod. If I remember it was a two relay mod.
This post has all the schematics for the headlight relays. http://www.fiatspider.com/f08/viewtopic ... 8eeda60053
I think I ultimatly went with a combination of #2 and #4 I wired the relays into the system in a fashion that if I want to remove them I can just re-connect the existing wiring.
SpiderJim
Post by SpiderJim »
You are my hero.. Thanks so much I knew I had seen it somewhere.
JIm
