15 inch wheel on an x, any thoughts
less then an inch taller then what i took off. might need a little shorter tire and different center cap. overall not to bad in my opinion
- manoa matt
Re: 15 inch wheel on an x, any thoughts
Is that a big thick 4X98 to 4X10 wheel adapter I see behind the wheel? The proportions look good. If It were me, I'd keep that sidewall height, go too low and it will be a rough ride.
Ditch the Honda center cap unless you are going to put a big round muffler and unpainted body kit on the car. Remember Italian cars run on pasta not rice.
yes, that is a wheel adaptor.. it puts the wheel out at the perfect spot. about a half inch between the tire and spring. and the honda trans thats going in the car is geared for that size roughly. im working on a different center cap, that wheel came off a honda less then a minute before i put it on the x to see what it would look like.
If I were British I would have to say "very nish"
