Some "after" pics of the engine
digitech
Post by digitech »
Here are a few "after" shots of my engine as I complete the second rebuild. I didn't really want a red engine but that's how the block came back from the machine shop and I wasn't in the mood to repaint. The tranny was cleaned up/rebuilt by Vicks and I painted it with aluminum paint; mounts, gaskets, oil seals and throwout bearing are new.
mdrburchette
Re: Some "after" pics of the engine
Post by mdrburchette »
Looking good! If your car was red, I'd say the red block would be too much, but I think it'll be just fine with a white car.
racydave
Post by racydave »
Sweet! I like the red too!
ventura ace
Post by ventura ace »
mdrburchette wrote:Looking good! If your car was red, I'd say the red block would be too much, but I think it'll be just fine with a white car.
My original engine color was red, in a red spider. Yes, it was a bit much, and the reason why I used grey for the engine I have in there now. I think the red looks great for your weddng-gown white car! That's gotta be the cleanest I've seen (your pictures of the engine bay, relays, etc.). I hope you plan on keeping that clean --- not!
Interesting . . . I haven't seen a water pump and pulley combination like yours before. The ones I'm used to have a longer shaft, so the pulley is dished in the other direction.
Alvon
Good catch Ace, I noticed that too. I think the pulley is installed on the pump backwards. That transmission looks awesome, engine too. The Valeo clutch cover looks different than others I've seen, where did you get it? Is it an uprated design?
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Boy, that's really looking good! Are you running an oil cooler or just a remote filter?
Trey
digitech
Post by digitech »
Thanks for the observations - I'll be really embarrassed if the water pump pulley is on backwards, I'll check on it! The clutch is from IAP; I used one from them before on the first rebuild and it worked fine. I am running an oil cooler, I don't think it can hurt in Atlanta. I am dry fitting the head now and found I am missing a head to block alignment dowel if anyone has one. I will post in PW as well.
NJFIAT1981
Your car is a: 1970 SPIDER AND A 1976 SPIDER
Post by NJFIAT1981 »
Looks great. Have an engine out of a parts car that I will be taking apart Wed. night. Hope it turns out as well as yours looks. I like the red engine block. Nice contrast.
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Post by kristoj »
Wow. That looks VERY nice!
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
