Opening the Trunk
deftone
Opening the Trunk
Post by deftone »
I dont have a key that fits my trunk....is there anyway of opening the trunk without one? The key that fits my ignition doesnt fit my door locks.....and as the car was sitting in a field since '85, the door keys are missing,
Re: Opening the Trunk
If you remove the licence plate and drill a 1/8" hole in the middle about 1-2 inches down you can use a small screwdriver or pick to pop the lock latch.
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
A good locksmith can start with a blank and make a key by hand. They put in the blank, wiggle it a little, file where the key is scratched by the tumblers and repeat until they have a key that works. Gotta find a locksmith though, that is a locksmith.
Ron
Ron Luxmore
rlux2n2@gmail.com
MNspiderman
Post by MNspiderman »
dont forget when picking the trunk, it turns to the left, not the right and has a fairly heavy spring resisting your turn action.
