The '76 /1800 I bought came with a DHSA carb. It ran decent once warmed up but bad when cold. The aftermarket manual choke was broken and the screw hole on the carb stripped. Since I read this isn't the most desirable carb and I was doing other work (timing belt, water pump, etc) I swapped it with a 32ADFA2 I have from a parts car. I don't think this carb has ran for about 10 years but it seems like it's in decent shape.
So I bolted it on with a bunch of guess work and it runs like crap. Main problem is puffs (backfire?) coming out of the carb every few seconds. Yes, I know I jumped the gun a bit with just throwing it on there. Anyway, now I'm trying to figure out what connects to where by looking at the parts car.
I think I have most of it right but I don't know where the 2 tiny vaccuum lines at the bottom of the carb connect to? It looks like maybe the vapor canister but that's removed on my car. The other goes to a part next to the ignition coil (going from memory) but I don't see that on my car either. Can I just block them off? I'm not even sure if my parts car is a good reference point.
Also, I did not connect the idle solenoid which is apparently a good reason why it won't idle
I know, maybe I'm nuts for trying to run this carb after it sat for so long, but I figured it's worth a shot... or is it not? Either way, I still need to know how to connect it properly!
