I got the replacement starter in without much trouble. It's hard to tell how good the starter is, the car started on the first click. So, I'm sitting in the car, listening to it hum, and I start smell a strong gas odor. I shut it down, looked under the hood and the whole side of the engine under the fuel rail is wet. I couldn't tell where it came from, so I restarted it, looked in the engine bay and saw massive amounts of gas spewing from the hose connected to the hard line coming from the tank. I put the starter in from the top side (easy to do with the 2 litre FI, there's about 8 inches clearance below the manifold.) In the process I pushed on the rubber fuel hose and it broke. So... I got the replacement FI fuel hose put in and started it up, looked good, so I went on a little drive. When I got home and parked it, as I was walking around it (kind of admiring it, you know, the way ya do), and my right rear tire is flat! I repaired it and it's good to go.
I think I wore out the Fiat Gremlins, so I should be safe for the drive up to Oregon 09 next month.
Ron
