Small Bump on a FI?
launieg
Small Bump on a FI?
Post by launieg »
Does anyone know if the small bump hood will fit over the Fuel Injection? I want to do a temporary swap. Thanks.
Launie
Re: Small Bump on a FI?
you'll get contact at the top of the plenum where the cable mount is. The only way it fits is if you don't latch the hood
launieg
Post by launieg »
Thanks Mark. I'll try propping it up a bit somehow. Maybe I can angle the hinge brackets up a bit, with only one bolt in each one, and then be able to latch it. I just can't bear to miss driving when the weather is so perfect!
Launie
