Engine seems to seems to skip or spudder once in a while.
RoadRacer
Post by RoadRacer »
Engine seems to seems to skip or spudder once in a while, while driving.... My car was running terrible, so I took the cap off and noticed the rotor was in pieces and the nuts that hold the rotor down were off and stuck in the cap (real mess).
I changed the rotor, cap, plugs, wires and reset the timing. Car sounds much better... Now when I drive I have to keep it revved up or she will spudder or slight skip once in a while. (is spudder a word?) It does it allot if I am doing 40 in 4th gear, I have to go down to third....... :? What could be my problem?
mbouse
Re: Engine seems to seems to skip or spudder once in a while.
Post by mbouse »
when you changed the wires, did you change the magnetic pickup? that shrapnel flying around the inside of the dizzy usually plays havoc with the mag/pickup wires as well. short those buggers out and you will have erratic at best, ignition.
RoadRacer
Post by RoadRacer »
No, I did not change the magnetic pick up........ I will order one now. Thanks
mbouse
Post by mbouse »
wouldn't stand in your way of that decision, but it is a simple thing to check. simply pull the dizzy cap off and look at the wires.
of course, i have a spare mag pickup on hand at all times.
fiasco
Post by fiasco »
Did you change the condensers when you changed the other stuff. Your symptoms sound a lot like what I was experiencing. Slowly got worse over time until the car just quit running and I was forced to do something about it. Replaced the condensers (I had two because of dual points setup) and she started running smooth again.
-- se
Steve Eubanks
RoadRacer
Post by RoadRacer »
Does the 82 have a condenser?
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Yup. It connects to the coil's positive terminal.
Ron
Ron Luxmore
rlux2n2@gmail.com
RoadRacer
Post by RoadRacer »
Well, I got the magnetic pick up today and installed it....... Car runs great now. :D
While I was removing the old one I noticed one of the wires was broken off where it goes into the magnetic pick up.
Good call mbouse Thanks.......
baltobernie
Post by baltobernie »
Oh no, that's two in a row for Mike. Wait until he finds out ...
