engines
fiat218
engines
Post by fiat218 »
is the alfa romero and fiat engine;s sorta the that same built?
as in 2.0
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Re: engines
they are the same in that they are both iron block, aluminum head, dohc engines
engineerted
Your car is a: 1974 124 spider
Re: engines
Post by engineerted »
Mark, I believe that the Alfa 1750 - 2l motors are aluminum head/blocks with drop in iron sleeves. This makes them easy to rebuild.
Ted
Ted
bradartigue
Re: engines
Post by bradartigue »
There is very little the same. They both have twin camshafts and eight valves, that's about it.
Alfa is an aluminum wet-liner block; FIAT is cast iron with bored cylinders. Alfa is chain driven internal gearing; FIAT is belt driven, external driven. The intake is on the opposite sides.
And on and on...
fiat218
Re: engines
Post by fiat218 »
i was gonna say , i have a alfa and it is aluminum block
i was just wondering how different they are.
in rebuilding which engine is more ( what is the word i want ) hmm
more sophisticated ( complex
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
kmead
Re: engines
Post by kmead »
Generally the Alfa engine can produce more power but is not cheap to build up. So by that measure (more power) the Alfa engine is more sophisticated. It is also harder to rebuild and needs more care in the build up. Once its done though its a pretty bulletproof engine.
edited to clarify a statement
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
