On The Road Again!
fiasco
On The Road Again!
Post by fiasco »
It's official. I'm back on the road. I got everything put back together and buttoned up tight, and drove it around the block a couple of times. No oil leaking anywhere that I can see so far. The radiator is still leaking, but not from the place where I got it fixed. Actually, I think I tightened the drain plug too much and cracked it because it seems like that's where the leak is coming from. But, other than that, I'm driving again.
It feels good.
-- se
PS, every bit of black paint burned off the exhaust manifold, and it is now ash grey again. :roll:
Steve Eubanks
ventura ace
Re: On The Road Again!
Post by ventura ace »
Congrats again, Steve -- for all but the leak, of course. Try to get a real good idea where the leak is before taking it in to be fixed. Sometimes if it is a really small leak that only leaks when the radiator is hot, the radiator shop may not be able to duplicate the problem and find the leak. Keep a close eye on the water level and engine temp, and shut it off if it is overheating. I'm sure you are not eager to be building another engine anytime soon!
Alvon
If you can solder a pipe joint then you can fix that drain plug leak. The key is to clean the area well down to bare metal. Watch the heat as you don't want to transfer too much heat to the lower cap or the cap joint can de-solder.
jimincalif
Your car is a: 1980 FI Spider
Post by jimincalif »
Congratulations!
1980 FI Spider
SpiderHead
Post by SpiderHead »
WoooHoo!
you owe us a walkthrough of how you resolved the clearance issue!
Gratz brother!
-Ryan
kilrwail
Post by kilrwail »
Glad to hear you were able to solve the rad problem with Mark's help. Congratulations on a big job well done, by all concerend!
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
fiasco
Post by fiasco »
SpiderHead wrote:WoooHoo!
Gratz brother!
-Ryan
Bought a slimline electric fan from Mark. About 2 1/4 inches deep. I'll post a pic tonight.
-- se
Steve Eubanks
TulsaSpider
Post by TulsaSpider »
Allright! Congrats Steve! 8)
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Steve, show the gang a picture of how good the engine looks in the car.
You did a good job of choosing the engine colors to go with your black car.
Ron
Ron Luxmore
rlux2n2@gmail.com
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Post by kristoj »
Congrats Steve! Great to hear.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
fiasco
Post by fiasco »
rlux4 wrote:Steve, show the gang a picture of how good the engine looks in the car.
Ron
I'll get some tomorrow in the daylight.
-- se
Steve Eubanks
SpiderHead
That's great Steve!
Congrats!
You up for a camping road trip to Paso Robles? Check Ace's post under events.
Be a great shakedown for your machine!
-Ryan
Tappy
Your car is a: 124 spider 2000 1979
Post by Tappy »
congrats steve
for the exhoust paint , did you use heat resitand paint ? none of them would hold up great but if you apply the paint when the exhoust is a little hot the paint bakes in better and holds up longer
heatresitand paint needs to be baked in or it would just as long as normal paint ; just some tours arround the block :)
FineItalianAutomobile TechnologyImage
fiasco
Post by fiasco »
SpiderHead wrote:That's great Steve!
Congrats!
-Ryan
Not this time. I have several weekends of inattention to anything but the car that I need to make up over the next couple of weeks.
-- se
Steve Eubanks
ga.spyder
Post by ga.spyder »
Congrats,Steve
What an effort by all you guys!Looking forward to the pics.
Craig
Craig Nelson
Fling It Around Turns !
