I live in N. Cal., there isn't any sun!TulsaSpider wrote:Wow I'd be concerned about being blinded when the sun hits that!
Today was a easy day, I spent it taking apart the gauges and cleaning them. I did stab my hand with a screwdriver a few times while prying off the bezels.So Cal Mark wrote:such a clean hand!
Wow, tht came out really good! I know I can salvage the bezel, I just didn't want to spend hours on it like on the tail lamp bezels. I think another hour with a razor blade might do it, but if not, I'll be in touch.seubanks wrote:Trey - as far as the center bezel is concerned, I had no luck with mine. Couldn't get the old chrome and black off enough to satisfy. I made a replacement with wood for the frame, mahogany insert panels (deleted all the warning lights, but you wouldn't have to if you didn't want to), and a strip of adhesive "chrome" trim for the center section. I painted the frame with black crinkle paint. It looks pretty good with the darker mahogany I veneered the dash inserts with.
If you end up unhappy with your stock bezel, let me know and I can whip you up a frame, and you can put whatever inserts in that you want. I think your aluminum top and bottom would look great with wood in the middle, just as a little nod to tradition.
-- se
Ya, I've got lot's to do! On the '82 I cut out the ashtray grille, but left the lid, so It's now a storage tray.mbouse wrote:as previously stated, watch what chemicals you use on plastic. i'd prefer hearing you used some 000 steel wool rather than chemicals.
don't forget to check your specific crackle paint to see if it will adhere to the plastic. you may have to precede the finish coat with some etching primer.
is it safe to presume that the ash tray is getting it's own coat of crackle? or, maybe a conversion to another use?
http://flumichigan.italiancarclub.com/T ... shtray.pdf
Ya, I figured I'd paint it with Mike's crinkle paint.mdrburchette wrote:Trey, do you have a dremel? Maybe one of those little scotch brite discs on the dremel will take the rest of the chrome off your bezel. Are you painting the bezel when you're done?
