Well, Part 1 of the engine transplant is done, we got the old motor out. The top tranny bolts that everyone says is a pain in the butt really werent the hard. The big sticking points during the removal were taking off frozen exhaust manifold studs and finding that third starter bolt that the manual I have conviently forgot to mention.
We just took the engine out without the tranny. This was a first time engine removal for me and the first time RWD engine removal for my best friend Andrew who helped me out. I think it took us about six hours to do. Now just have to get the damn flywheel off.
I got ten days to get the new motor in for the Club meeting in Saint Augustine, otherwise I am going to have to take the Alfa!
Once I figure out how to post pictures I will...
Engine Saga
Trying to say I got beat by a girl?
We just pulled the engine because we figured it would be the easier of the two procedures. Since I havent done it with ANY method I really have no idea what is easier. As soon as everything was disconnected though it came right out with no problems. I read a lot of debates in Mira about which procedures is best bleh bleh and am happy with what we did.
Has anyone ever used "wrinkle" style or similiar engine paint on valve covers and the like? I want to make some on the parts on the new engine look good with the hassle and cost of powdercoating.
depends on the car. My first spider, a 76, was a serious PITA to get to the top transmission bolts. The trans was not even an inch from the top of the trans tunnel. I remember something about three swivels and about three feet of extensions to bring the rachet down to the shift opening in the tunnel.
My 75 had a ton of room between the trans and the tunnel. Never did figure out what was different between the two cars.
Well we got the engine in. It took a VERY LONG TIME to get the input shaft of the tranny into the pilot bearing and get the engine into position. I think if I ever pull the engine again i will do it with the tranny attached...
I hooked up the megasquirt and EDIS ignition and after a little tweeking I got the motor fired up. Problem is nowit have oil leaking from the intake side cambox and I am afraid the gasket is damaged. So we ran the engine for a grand total of 2 minutes. 'Suppose it time to take the timing belt off and replace that gasket.
I had the timing set at 10 degrees and the air fuel ratio at a nice safe 12.5:1 which of course is ridiculously rich but I didnt have a chance to change it out of fear of warming the engine up before we had the chance to break it in. I couldnt remember if I remember to fill up the tank with higher octane gas in anticipation for the HC pistons so I filled about 3/4 of the tank with 92 octane I picked up from the gas station today.
Ya I thought the leak was odd too. I took apart the cam box and put on a new gasket today and reinforced it with gasket sealant. The motor started the up and no more leak. I think the old gasket was damaged before it was put on. Dunno for sure.
I found a few water leaks from the hoses that lead from the block to the heater. I tried to reuse the old hose but it is a little stiff and didnt fit back on very well. Anyone know a good replacement or fix that can be had locally?
I also must have a big vacuum leak somewhere because the engine wants to idle at 1800 rpm. It could be that the throttle stop screw isnt properly adjusted I will check that tomorrow after I chase down the leaks. I also disconnected the Fast idle solenoid to see if that was the problem but no change.
