okay... so I replaced the front light bulbs on my 78 spider (WITH 1157 bulbs). Now, i have lost power to fuel guage, temp guage and the signals do not work? Any help or suggestions?
Bob
front blinkers/turn signals
- Patron 2024
If you have a volt meter or trouble light I would check for power to the lamps. I don't have a wire diagram for a 78. But I am guessing the ground for each lamp would at the grounding point for the corresponding fender. The ground for the guages would be under the panel. In other words there are 3 grounds points. I'm thinking chances are a fuse blew. Or there is a bad connection on the fuse panel.
