Whereas the voltage to the headlights was probably down around 9 – 10 volts for my 39 year old original headlight wiring, the relay kit jumps the headlight voltage right up to almost full battery / alternator voltage (13+ Volts). The increase in headlight brightness was remarkable. Used to be, I’d have to turn the headlight switch on / off just to assure myself that the headlights were indeed on, and it didn’t really matter how the dim/bright switch was set. Now, I’ve got beams shining brightly in front of the car. Cars coming toward me are actually flashing their lights to let me know the brights were bugging them!
I’ve read about this highly recommended modification many times over the last several years, but didn’t do anything because I’m not all that keen on electronics or knowing how to find the correct stuff to do the job. There have been several threads offering good instructions and links to sites for buying relays and such for about $30 - $40, but I was still overwhelmed with the challenge of finding the correct wire, the correct end connectors to mate with existing wiring, making good crimp connections, figuring out where to put all that extra wiring without cluttering up my clean engine bay, etc. Then, I saw Greg putting in the mod for several folks up in Oregon and was surprised with how easy he made it look.
Greg’s fantastic price of $70 (including shipping) gives you everything you need, including a set of very clear, complete instructions. The parts are rugged and suitable for the operating environment. The kit includes an in line fuse for convenience and safety. The wire lengths are perfect for anywhere that you would want to mount it. The product worked exactly like it should the first time I powered up. The kit looks very neat for prominent display, or if you like to keep things looking original, it’s small enough to be tucked away and out of sight, like so:
Can’t find it, huh? It’s in the little access cavity for the top of the passenger side front shock. You can see the red and black power and ground wires disappearing under the WW bag, and the black wireloom routed behind the battery that takes the juice over to the driver side headlight. On the driver side, the pic shows my stock headlight cable in front of the horns, connecting to Greg’s kit wires out of sight in front of the radiator.
You can contact Gregory at gfs@gregoryfsmith.com. Thanks Gregory!
