205/60R14s on 14 x 6 Rims?
dcroop
Your car is a: 1982 Fiat Spider
Post by dcroop »
I just bought a set of 14 x 6 Panasports for my 82 Spider with the IAP sport springs on it. Can anyone confirm that 205/60R14s will fit OK without rubbing, etc? I suspect they will be fine, but would like to know if anyone is running this rim/tire combo. I know the stock size was 185/60R14, but seems like there are more options for tires in the 205/60R14 size.
Any replies will be greatly appreciated.
jfrawley
Your car is a: 1982 Spider
Re: 205/60R14s on 14 x 6 Rims?
Post by jfrawley »
I'm running 195/60R14's on my '82 with no problems. I wanted a 205 but I didn't like the sidewall buldge, so I went with the 195's.
John
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
mdrburchette
Post by mdrburchette »
I'm running 205/60/13's on a 6" wheel on my 72 with no tire scrubbing and have a 195/55/14 autocross tire on turbo wheels that also fit just fine on the car. I believe Fiatcolumbia is running 15X7 wheels on his with no tire scrub.
ga.spyder
Post by ga.spyder »
I am running 15x7's on my 82 with no tire rub issues.Tires are 205-50x15's.I did remove the spacers to set the tires in a little,no rubbing still.
Craig
Craig Nelson
Fling It Around Turns !
dcorder
Post by dcorder »
I'm running the same rim/tire/spring as you and I have a small amount of rubbing when making a hard turn. Dave
dcroop
Post by dcroop »
Thanks everyone forthe responses. I was a little bit surprised to hear that 205s would be have some side bulge on a 14x6 rim. I don't want side bulges either, so I may look into the 195 width. Thanks all.
narfire
Post by narfire »
I am running 15 X 7's with 205/50 toyos.(80 spider) no rubbing unless your wheel well liner is not screwed down well.
ga.spyder
Post by ga.spyder »
I am not sure what a 'side bulge' is,but the difference between a 195 and 205 tire with the same aspect ratio(60 series) is only 1/4'' in width.I cant imagine that would make much difference at all.With a lot of us running 50 series tire which have less sidewall and a lower profile,I think any 60 series tire would be fine with no issues on rubbing.The only time I have had rub was when my wheel well liner loosened up,like narfire stated.Quick fix! The offset of the wheel you use could have a lot to do with how the tires fit into the wheel wells.Good luck,and post some pics after you decide which way to go.
Craig
Craig Nelson
brad131a4
Post by brad131a4 »
I'm running 225/45/14 on 8" rims on the back and have no problems. I have 195/40/14 on 7" rims on front with the car lowered on top of them and I have no rubbing issues. With what you described I'd have a hard time thinking you'd even come close to rubbing on anything.
