Can I ask another basic 'newbie' question please?
I want to replace the ill-fitting after-market locking fuel filler cap on my US-spec 1982 Spider 2000 FI with a non-locking type cap.
I have discovered that a generic European FIAT screw-on fuel filler cap will fit the fuel filler neck of my car. The only problem is that these caps seem to come in two types, vented or non-vented. Can anyone tell me what original type would have been fitted to an FI car, vented or non-vented?
Grateful for any responses, many thanks in advance.
Fuel Filler Cap Q?
Re: Fuel Filler Cap Q?
The cap on my '82 looks pretty original and it's non vented.
Ron
Ron
unless you have emission testing where the evaporative system is checked to hold pressure, I'd use the vented cap
- TulsaSpider
Just curious Mark but what is the reasoning? Mine must be unvented cause it always releases pressure audibly when I open it.
there have been several threads about cars acting like they were out of gas, when the culprit was a vacuum in the tank. Since I haven't been involved in diagnosing one of those cars, I'm not sure what caused it. It may have been a malfunction in the evap system, or mods made by an owner that caused it, but the vented cap would prevent the problem
I had a new 1970 124 sport coupe that had that issue. If I filled up the tank and got on the freeway and drove the car would cut out like it was out of gas at about 1/2 tank. If I got out and opened the cap you hear the thing sucking air in. Then I could then drive on until it was time to fill up and start over again. It wold also build up pressure on hot days when I didn't drive much. When you took the cap off then it would blow gas all over the poor attendant, no self service in those day. That cap was not vented but I sure wished it was. I took to leaving the cap loose most of the time.
I eventually found the problem. It was a three or four way valve in the evap system that was installed backwards.
Many thanks!
As always, this forum turns up quality informed responses. I am very grateful for your fast replies.
Thank you again.
Thank you again.
