Hi all !
I have a Fiat spider 1981 inj. 5 speed, like new, 50K
I have now a big trouble with it ;
when the engine become warm , the idle it's badly rough ,it's missing a lot ..No more power. With accelerator pedal in the floor, the maximum speed is 10 miles by hours and the catalytic converter become very red. The engine running on 2 or 3 cylinder without power at all and also the engine stall.
what was done :
first test the catalytic covertor with test pipe…problem was still there…
We clean the fuel tank, all gas line, replace gas filter, air filter and test the electric fuel pump (the pressure was perfect even the problem happening). problem was still there…
We replace timing belt, lambda probe and ignition coil. Problem was still there
Now we will replace the ignition control module and pick up coil…after that we don’t know…what we have to do ?
Somebody can help me, please ?
