Can we get the board adjusted to reflect the correct time? Since the time change mine has been off an hour.
Chris
Daylight Savings Time/Standard Time
Re: Daylight Savings Time/Standard Time
Hey Chris,
You have to adjust it your self. Under user control panel --> Board preferences --> edit global settings.
Click NO on Summertime/DTS is in effect, and hit submit.
i find that SAVING TIME is always possible when one correctly uses this forum.
Where else do you talk about TIME(ing)?
Where else do we swap USED parts, for less?
Most of my posts are during the DAY.
Where else can you getta QUICK laugh?
each one related to DAYLIGHT or SAVING and TIME.
Thanks guys that worked. This was the only message board I had to do that to.
