Broken studs on anti-sway bar support
stupidsongs2
Post by stupidsongs2 »
I broke off both the studs on the passenger side, inner support.
Suggestions to getting back on the road as quickly as possible?
ventura ace
Re: Broken studs on anti-sway bar support
Post by ventura ace »
I would never know, but Denise tells me that you can drill them out and put in a grade 8 bolt. And if you drill out to one size larger, you can put in a larger bolt, which you really need on the larger diameter sway bar like she has on her spider.
Alvon
stupidsongs2
Can it be driven without the sway bar? My girlfriend needs to get to work tomorrow and the bus is broken down too. Nothing highway speed and it's only about 3 miles each way.
ventura ace
I don't see why not. Just don't get crazy with it. Drive like your granny, especially when it comes to turns.
Alvon
mdrburchette
Post by mdrburchette »
Alvon, he's talking about the inner support. I believe it's welded on, unlike the ends that we did on my car. As for driving it without the sway bar, I didn't feel any difference driving in town.
ventura ace
Thanks for the correction, D.
I haven't had to deal with the inner ones, but I think I would take the old stud down flush to the frame, and then attempt to drill it out and thread the hole to accept a bolt. I don't know how thick the unibody frame is in that area, but if it is thick enough, this should hold fine. If not, you may have to cut a hole in the frame to allow putting a nut on the back side, or put a bolt in from the back side.
Alvon
ga.spyder
Post by ga.spyder »
If it is the same as the 82 ,you will have to thread the hole as the frame is 'boxed and there isnt anyway to put a bolt thru. I broke 1 of mine and temporarily drilled another hole and put a large self tapping screw in. Drove it for a couple weeks before drilling out the stud,threading,and installing a bolt.Careful if you are driving w/o sway bar. I jury rigged mine because there are no straight roads up here!
Craig
Craig Nelson
Fling It Around Turns !
stupidsongs2
Well, both the studs have about a half inch left on them.
What my plan for now is:
Get two 8mm threaded extenders and snug them down on the remains of the studs
Drill out the support brackets so they'll fit over the new extenders (they are about 13mm wide instead of 8mm)
Install with bolts that screw into the extenders, and spacers that go over the extenders so tightening the bolts puts pressure on the brackets
I figure at worst this method will leave me with two worthless support brackets, and the studs broken off so I can drill them
out easier
apexwc
Post by apexwc »
Would this work if you replaced the slotted screw with a hex head? Once the threaded portion is installed it stays in place if you remove the bolt. I don't know how thick the frame is but this might be a little stronger than just drilling and tapping the hole.
