Spider won't shift into reverse
My 1974 Fiat Spider 124 won't shift into reverse, unless I shut the car off then restart it, even then it isn't easy. Does anyone know the remedy for this? thanks!
if it goes into rev with the engine off, it sounds like your clutch isn't releasing. There should only be about 3/4 inch free play at the top of the pedal. If you have more, the cable may be stretching and close to failure, or the firewall may be cracked and flexing, or the clutch pedal may be cracked and flexing.
Worst case, the clutch is worn out, does it slip when accelerating in 3rd or 4th gear?
