How to search ??? Need help please
If you have and idea, a problem, or an accolade, post here.
Rweiss6
Patron 2024
Patron 2024
Post by Rweiss6 »
I want to search “ignition switch” but search brings every post that has “ignition” and “switch” Tried few diff ways, always same results
How to search for IGNITION SWITCH only if these two words are together ? Thank you !!!
I posted question today , but archives have been very helpful in the past.
Re: How to search ??? Need help please
Did you put "ignition switch" in quotes when you searched? Perhaps "ignition" + "switch" (be sure to include the "+")?
Or, you can search using Google directly: Type "Site: fiatspider.com "ignition" + "switch""
Rweiss6
Patron 2024
Patron 2024
Post by Rweiss6 »
I did try “ignition”+”switch” with and without + and/or parentheses but always got posts with either ignition or switch.
Your suggestion to use Google does work, but it’s not in forum directly , def an improvement- thanks , but
I would think there’s a way to search that way here.
If anyone knows how , please advise
