Ballast resistor yes or no?
Gotta love that wiring . . .
70spider
Your car is a: 1970 Fiat spider
Post by 70spider »
Hello,
I am in the process of returning my spider to points. My question is about the coi.l I understand that the original coils were 1.5 ohm and required the ballast resister, however the coils I have found for sale today are 3 ohm and say not to use with a ballast. So do I bypass the ballast and run the ground wire from the distributor (points and condenser) to the negative of the coil? Or do I still wire it thru the ballast?
Thanks.
2002 Mazda Protege5
2013 Buddy 170i
Re: Ballast resistor yes or no?
Early spiders work well with a total primary circuit resistance of about 2.5 ohms. So, if you have a 3 ohm coil, you don't need a ballast resistor. You could still use the resistor and it would probably work, but the spark wouldn't be as hot.
You're right, the original coil was about 1.5 ohms plus a 1 ohm ballast resistor for a total resistance of 2.5 ohms.
If you use a much newer coil with less than 1 ohm resistance, you definitely need a ballast resistor. The smaller the overall resistance, the higher the current through the circuit, and with low resistance coils, you run more amps through the points than they were designed for.
To bypass the resistor, you just run the wire from the distributor directly to the negative terminal on the coil. The brown tachometer lead would also connect there as well.
