coiloves
Re: coiloves
I have heard of folks doing this, although I can't provide any details and it's pretty rare. The most common conversion is to electronic ignition, although that can have problems itself. Old-School guy that I am, I have always found the stock points ignition system to be just fine when working properly.
That being said, if you do have the dual points setup in the distributor, that was a royal pain to get it working properly all the time. Converting to a single set of points (or electronic ignition) is pretty common. I think dual points were used from 1975 to 1978 or thereabouts.
- Your car is a: 1976 fiat 124 spider
Re: coiloves
LOL shocks .... coilover shocks
Re: coiloves
LOL is right, sorry 'bout that! Being an engine guy and not a suspension guy, I immediately thought coil over plug...
I don't have any experience with coil over shocks, so I can't help you there.
Re: coiloves
There is no place to mount the top of the strut w/o massive body/frame fabrication.1976spyd wrote:I have a 1976 fiat 124 spider and was thinking if anyone has put a set of coil over on their car ? don't know if there is any room for them, if someone has done this, please let me know, Thank you!
Why would you want to do it anyway? Double wishbone is very nice as long as the bushings are in OK shape.
Re: coiloves
I just thought they would be easy to adjust, I have brand new front end I bought from vics alone with their Wilwood brake kit. I will stick with what I have Thank you
