radiator is removed - what else should I do?
geoff
Your car is a: 1982 Spider
Post by geoff »
Hi all
I have my radiator out awaiting a new one and I am thinking that it would be a wise thing to do some other work whilst the access is good.
I am thinking of replacing the timing belt and alternator belt. Can anyone suggest what else might be a good idea to change at this time?
best regards
Nut124
Re: radiator is removed - what else should I do?
Post by Nut124 »
If you do the timing belt, I'd do the belt tensioner and the water pump.
Do you know the mileage on the timing belt? Water pump leak?
Nut124
