Hi Guys,
I have a 1979 2.0 and I need 4x flat 84.6mm pistons BUT they need to have the larger Valve cut outs, not the smaller ones. If anyone can help I'd be eternally grateful.
84.6mm FLAT Pistons needed
- Your car is a: 1978 124
Re: 84.6mm FLAT Pistons needed
Why do you need flat pistons w large valve cutouts?
Are you running super size valves?
