Not sure if this is a dumb question but... while fixing the passenger speaker wiring, I took a glance at the heater control valve. It is severly corroded, in fact its missing the top half where the cable connects to divert flow.
I assume this is a MAJOR risk for leaking inside the cabin, right? I have no idea how this thing isnt leaking right now to be honest.
I imagine a thin layer of rubber (thats old and dry) is all thats left holding the fluid in and not leaking. My plan was quickly grab some 5/8" ID heater hose, drain the system down, and bypass the heater core all together in the engine bay.
Thoughts?
Here is a pic: http://www.essenz.com/valve.jpg
Rotting heater control valve? Risk?
- Your car is a: 1984 Pininfarina Azzurra
Re: Rotting heater control valve? Risk?
Yikes! Given the state of your valve, I think this is a good course of action. Corrosion and solidified coolant may be all that is keeping your valve from leaking. In time, you might want to replace the heater core and valve and remove the bypass hose in the engine compartment.essenz wrote:My plan was quickly grab some 5/8" ID heater hose, drain the system down, and bypass the heater core all together in the engine bay.
Thoughts?
Yep, just bypassed it this morning with a 5/8" barb splice, then vacuumed out what was left in the heater core.
Eventually I'll replace the heater control valve, but for now its not a priority considering my heater in general doesn't work (something electrical with the fan not turning on).
It was a good opportunity to flush the flush old coolant too. Wasn't that dirty, but the concentration seemed a bit glycol heavy to the eye, so now I have a clean 50/50 in there.
Just got her up to temp, cooling down now and will bleed out any air for the bleeder T in an hour, then take a nice 50 deg Sunday cruise.
I'm really glad I spotted this while fixing the speaker wire. I recently got this car, and it was in very very good shape, but after a week of close inspection I have found several small things like rubbed/frayed wire on the Lamda sensor (fixed), cracked/slipped off vacuum hose on the fuel pressure regulator, additional frayed wires during the speaker fix.
