Hello,
I am looking to replace my heater lever control panel, just the metal part. The levers work fine, but the metal trim part was broken by the previous owner. I would like to replace this, but have not found any information on how to do this. It seems reasonably simply, but I just want to make sure I do not need to dissemble the entire assembly to replace this part. Reason being because I am not sure how the panel will fit with the rubber tips on top of the levers. Any help is appreciated. Thank you!
Heater Control Lever Panel
- Contact:
- Your car is a: 1980 FI 124 spider
Re: Heater Control Lever Panel
All you have to do is pull up on the rubber tips they will come off the levers you mite have to use a little force but they will come off. Also after removing the four screws holding the chrome trim be careful when lifting, the fiber optic cable will be attached to the trim
1980 fiat spider under restoration
- Contact:
Ok, so if I ordered the piece off of Vick or Autoricambi, would the fiber optic just go back into the new trim easily?sweet124 wrote:All you have to do is pull up on the rubber tips they will come off the levers you mite have to use a little force but they will come off. Also after removing the four screws holding the chrome trim be careful when lifting, the fiber optic cable will be attached to the trim
The ends of the fiber optic cables have a little plastic clip to hold them into their positions on the chrome trim piece. These clips often break, but all you need to do is secure the fiber optics with a dab of silicone sealant or the like.Dahlstan wrote:Ok, so if I ordered the piece off of Vick or Autoricambi, would the fiber optic just go back into the new trim easily?
To be honest, I never thought the fiber optic lighting of the heating/cooling control panel was all that great, and it's not the end of the world to leave them off. If you do order a new control panel from Vick or AR, check with them to see that the part even has the receptacle for fiber optic cables. Not all the panels did, and I don't know about theirs.
- Contact:
Ok! perfect. Mine is completely trashed, IE Almost non-existent other than the metal around the center console so anything is an improvement. Hoping this makes the interior of the car all that nicer.18Fiatsandcounting wrote:The ends of the fiber optic cables have a little plastic clip to hold them into their positions on the chrome trim piece. These clips often break, but all you need to do is secure the fiber optics with a dab of silicone sealant or the like.Dahlstan wrote:Ok, so if I ordered the piece off of Vick or Autoricambi, would the fiber optic just go back into the new trim easily?
