cat or test pipe length
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
Hi all,
I think this is a simple question.....
Just got given an 81 which didn't run or have brakes, got most of that figured out but exhaust is an issue.
PO had the cat welded to the header and deleted the flanges.
I have a pair of flanges, but to put car back so that standard parts will fit i need the dimension flange to flange for a 4 bolt cat or test pipe. I can then cut the header/cat and install the flanges.
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
TX82FIAT
Re: cat or test pipe length
Post by TX82FIAT »
I'm pretty sure the 4 bolt used on the spider 2000 in 18" in length. I removed the CAT because of a blockage and pounded out the metal inside that was blocking the exhaust flow. The empty cat sounded terrible, so I then went to a straight pipe. Then in 2011, I had a mandrel bent 2.25" Exhaust installed from the header back with no CAT. Very loud. Now I have two mufflers, the forward muffler where the CAT was and it sounds deep and Italian without waking up the neighborhood in the morning.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
