Good day,
Today I started her up and it was all fine. Once the engine was nice and warm i revved her to about 3000 and it started going erratic.
I couldnt hold the revs at 3000 , it felt like it lost power and then regained it. ( i kept the pedal steady trying to keep 3000rpm) and eventually it just stalled. Idle is fine.
I changed : plugs, filter, oil and oil filter, plus last two parts of the exhaust.
I thought it was the hose from the filter box to the throttle so i changed that too. I checked the MAF and it opens and closes with no issue.
I cant put a lid on it. Was fine till now. This started a week back.
What do you think ?
Shaun
Engine Running strangely
- Your car is a: 1980 Fiat spider 2000 inj
Re: Engine Running strangely
Shaun, it sounds like something is restricting your fuel flow. Could be a clogged fuel filter, bad fuel pump, blockage in the lines, vacuum building up in the gas tank, etc.
Bryan,
I checked the hoses, i replaced the pump and filter. I checked the o2/lambda it looks ok. I also removed throttle sensor ( i regret it ! blasted screw underneath a major PITA)
No blockages as far i can see in the fuel hoses.
I have a video which i could send !
Shaun
Shaun
- Your car is a: 1981 fiat 2000
I had similar issue- and it was the fuel delivery siphon nipple from fuel tank - but before fuel pump. I add it had some “lawyer” like yellow chunks in it. I cleaned and added a pre-filter to prevent any of these particles ruining fuel pump. The filter later needed to be cleared from these particles a year later.
Ultimate solution (if this is problem) is to get new fuel tank
