Hairline scratch removal
blanchardkeith
Post by blanchardkeith »
Is there anything i can use that will help remove, hide, whatever the hairline scratches and swirl marks from drying my car. Got a recent paint job and now I can kill myself. Help!!!!
keith
Re: Hairline scratch removal
most of the wax mfgs make a swirl remover
mdrburchette
Post by mdrburchette »
If the scratches don't come out with a polish, you may have to have them buffed out. What are you using to wash and dry your car? I found a few techniques to keep from scratching the paint during a wash.
A wash mitt instead of a rag is good. Only use a good car wash soap, not dish detergent. I made that mistake once and ended up buffing the entire car because of water spots that were etched into the paint. When ready to dry, take the nozzle off your hose and let the water run all over your car. It helps the water drain off and not bead as much. An absorbent chamois is better than a towel to dry. Instead of wiping it dry, I either blot it dry or lay the chamois flat on the surface and pull it off the car. This will get the water off without applying pressure and rubbing.
blanchardkeith
Thanks. I think they will have to be buffed out. i have used macguires polish and an orange bottle scratch remover? thanks for the wash and dry tips!
Keith
